RTi A1 Surrounds with FXi3 rears???
dmbrown26
dmbrown26 Posts: 11
edited April 2008 in Speakers
I just purchased RTi A7s for my front left and right, a CSi A4 for my center, and RTi A1s for my surrounds. It was between the RTi A1s and the FXi A4s.
I am considering rear channels as well and wanted to know if anyone saw a problem with using FXi3s or FXI A4s for the rear surround channels?
I'm not sure how using rear bipole/dipole speakers for the rear and using standard directional speakers for the surrounds. Anyone ever do this? Any reason not too do this?
Thanks,
David
Post edited by dmbrown26 on
  • mike0311
    mike0311 Posts: 15
    edited April 2008
    David,
    I have a very similar setup. I am currently running a 5.1 but I am switching to a 7.1. I have the RTI A7s, CSI A4 and FXI A4s. The way my current setup is I have the FXI's on a back wall. When I am done with my theater they are going to be my side surrounds and I will get direct fire speakers for the rear surround. From the research that I did this seems to be the prefered setup having the di/bi's on the sides.
    Mike
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    dmbrown26 wrote: »
    Thanks,
    David
    No problem.
    You usually use the rear loudspeakers in Bipole mode.
    Yes. That configuration is 100% fine.....enjoy it, don't overthink it.
  • mike0311
    mike0311 Posts: 15
    edited April 2008
    I'm fairly new to all this, but if he has the RTI's and then gets the FXI aren't the FXI's better served as the side surrounds? I understand if you put the FXI's in the back you should run them bipole. Like I said, I'm new so not debating your post just trying to learn more.
    Mike
  • dorokusai
    edited April 2008
    The FXi series may serve as a side(Dipole) or back(Bipole) surround loudspeaker, hence, the bipole/dipole switch. In the end, this is subjective, and whatever sounds best is the solution.
  • mike0311
    mike0311 Posts: 15
    edited April 2008
    So if he only had one or the other, either is fine side or rear. If he has both, the FXI's are better for the sides? I understand ulitmately it is subjective.
