speaker wireing
does anybody know if there is a way to wire three 8 ohm speakers to come out at 8 ohms. thanks
Post edited by tom t on
Parallel?
I'm not sure how to get the same resistance.
Parallel Circuit
1/R = 1/R1 + 1/R2 + 1/R3
Series
R = R1 + R2 + R3 -
http://www.bcae1.com/spkrmlti.htm
Not happening if you want a equal amount of wattage to go to each speaker/driver."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
thanks, i dident think it would work
face, good web site there for speaker hookups,thanks
No problem."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
