subwoofer wiring help
thumpin07
thumpin07 Posts: 217
edited April 2008 in Car Audio & Electronics
I have a fusion EN-AM8001 Encounter Monoblock Amplifier, the spec are as follows:
Product Specifications
262 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
368 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
Max Power Rating: 800 Watts
THD @ Rated Power 1kHz/100Hz: 0.1%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 6dB/Octave
Bass Boost @ 45Hz: 0dB/6dB/12dB
Input Sensitivity: 0.2-8V
Input Impedance: 20K
Fuse Rating: 25A x 2
It is a 2ohm stable amp, my guestion is how do i wire my sub to be 2ohm stable?
The specs for the sub are as follows:
It is a Volfenhag zx-4712 1000w max 4ohm + 4ohm dual voice coil usable impedence is 2-8 ohm. How do i wire this thing at 2 ohm stable?
If i can wire my sub 2 ohm stable ill get more rms out of my amp
tyler
tyler birch
ht system
denon avr-1907
monitor 70 towers-polkaudio
nakamichi bx -100 tape deck
sony 5 disc cd/dvd player hdmi ready
velodyne dps-12 subwoofer
Car audio
AMP: FUSION EN-AM8001 800 watts max 368 watts rms x 1 channel @ 2 ohms stable
SUB: 12 INCH 1000W DVC VOLFENHAG 2 Ohm stable useable ohms 2-8ohms
Post edited by thumpin07 on
  • Jstas
    Jstas Posts: 14,996
    edited April 2008
    You don't have to post the same post in two different forums. If you are too impatient to wait until someone sees your post and has an opportunity to respond then you will be sorely disappointed in your endeavors here at Club Polk.
    Expert Moron Extraordinaire
  • thumpin07
    edited April 2008
    it was not that i was being impatient it was the fact i wasnt sure if i posted it in the right part of the forum. I apoligize for double posting, but i was just unsure where to put it, i apoligize.
    tyler birch
    ht system
    denon avr-1907
    Car audio
  • thumpin07
    edited April 2008
    I just dont understand how to wire it 2 ohm stable is all
    tyler birch
    ht system
    denon avr-1907
    Car audio
