In-Ceiling Speaker Help
karaim
I am installing in-ceiling speakers. I have a few questions.
1) I am afraid that my ceiling (made of sheetrock) won't be able to handl the weight of the speakers. Is there something that I can buy to install inside the ceiling, like a metal plate, to make it firmer?
2) I heard that insulation is good for in-ceiling speakers. What kind of insulation, where do I get it, and how do I install it?
Post edited by karaim on
Here are some mounting brackets: http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&CATID=16&ObjectGroup_ID=710
Any insulation should work; just try to use something that doesn't create too much dust. I don't think it would hurt the speaker, but it can't help. -
You should contact Polk or the manufacturer of the speakers. I contacted Polk about building an enclosure for my RC85I's. Polk responded with this line was considered "free-air" and to keep insulation away from the back of the speaker.
What kind of speakers are they?Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
For the front and center I have the TC80i's and for the surround and rear surround I have the RC80i's.
