RTiA9 Bi-Amping ?????
Neale13
Neale13 Posts: 88
edited April 2008 in Speakers
I have new rtia9;s. I have 2 outlaw mono amps,200 wpc. Onkyo 803 receiver 130 watts. Can I run the mids and highs from the receiver .Then run the subs from the outlaw. Is that ok. ? thanks:confused:
  • GEBBY44
    GEBBY44 Posts: 939
    edited April 2008
    It's best to bi-amp with the same amps. I would recommend trying it first the way you describe, with the receiver amps handling the highs and the Outlaws handling the lows. See how it sounds. If it's ok to you, then go with it. I've run a similar setup before and was satisfied with results, but some amps just don't play nice with receiver amps.
  • Neale13
    Neale13 Posts: 88
    edited April 2008
    Can I damage anything ?
  • tcrossma
    tcrossma Posts: 1,301
    edited April 2008
    I don't see why you couldn't do it, and I don't see how you could damage anything as long as you hook things up correctly. I'm not sure you'll gain anything by doing so, as I'd take 200wpc from those Outlaws over 130wpc from a receiver anyday. But it won't hurt to try.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • steveinaz
    steveinaz Posts: 19,546
    edited April 2008
    You could do it, but bi-amping in this method won't gain you anything. If it were me, I would just hook them up to the Outlaws.
