Question for CSiA6 Owner's
What is the height of this center channel when it is "upside down" and tilted up? I bought it on an overwhelming suggestion over the CSi3 and CSiA4 to match my RTi12's, despite the fact that I don't think I have a good place to put it. The bottom shelf of my TV stand will fit the 7 3/4" H, but not sure how much taller it becomes with the other configuration. The top shelf is a no-go and putting it on the top of the stand with my TV will take some work to raise the TV, as the bottom of the screen only sits some 6" off the shelf it sits on.
Post edited by bvbull200 on
nobody owns a CSiA6??!?!?!???!!!?
Anyone know a link to a forum where there might be an abundance of Polk CSiA6 owner's that would be able to take a quick measurement?
Hold your horses... I 'll go check now
I got 8 1/2" and that is conservative.
THANK YOU THANK YOU THANK YOU!!!! 100+ views in a Polk forum and no responses was driving me nuts!!!! 8 1/2" is conservative so it may be closer to 8 1/4" or closer to 8 3/4"? I'm afraid that, either way, I will be building a shelf above my TV as the fit on the stand may be a bit tight.
