Speaker Wire Along Baseboards?
wingnut4772
I am going to have to run my wire along the baseboards in my new bedroom setup. How is that normally done? More towards the bottom or the top? Is it ok to just staple it on there or do they sell something to help conceal it?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
Panduit hides it and even looks like an extension of the baseboard if choose the right style. here's some Panduit "raceway" styles/sizes:
http://www.panduit.com/search/search_results.asp?N=5000001+87&Ne=1®ion=USA&Nu=P_RollupKey
A word of WARNING: The sticky-back adhesive is very, very strong--it will take the top layer of your drywall with it should you ever want to remove it. I'd recommend just tack nailing it to the wall if you think you may want to remove it later.
This stuff is a plastic/nylon material and can be easily cut with a hacksaw/coping saw, and is paintable.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
In the past I have always just pushed the wire in the gap under the baseboard since the carpet has some give (depending on wire size of course). It's always been a no-cost option that I like.
I run this under my baseboard. When I'm feeling better, I plan on removing the baseboard cover and running it behind.
http://www.goertzaudio.com/flatwire.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Thanks. I will check it out.In the past I have always just pushed the wire in the gap under the baseboard since the carpet has some give (depending on wire size of course). It's always been a no-cost option that I like.
I have tile.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Thanks for the Panduit link, I like the looks of them
