Question for those serving . . .
SolidSqual
SolidSqual Posts: 5,218
edited April 2008 in The Clubhouse
Where and how did you store all your stuff? I am joining the Air Force and am wondering if all my stuff, especially my audio gear, will be safe in a climate controlled U-Store-It facility. Please bear in mind that it will be at least a year before I see any audio equipment again.
What are your experiences with storage facilities? What facilities would you recommend? Any good tips? Other companies or options to go with?
Thanks,
Mike
Post edited by SolidSqual on
  • MikeC78
    MikeC78 Posts: 2,315
    edited April 2008
    I actually got a good chuckle reading this, but with the AF nothing would ever surprise me.
    Your stuff will be in storage with usually the cheapest bidder the the military gets contracted with at the time. Climate control, good luck with that one. I suggest that when you get your stuff into storage, in that you pull out the most insurance you can get. Take pictures of everything and write it all down, make sure you have proof.
    Otherwise, you will need to pay for your own storage if you want something special. You might be able to get reimbursed for it, but you would have to contact your military advisor on that one. Maybe someone in the AF can give you a better answer, but you'd never get that kind of storage treatment in the other branches of service. Good luck...
  • MikeC78
    edited April 2008
    What did your recruiter say?:D
    Seriously; through all the BS... I'd get a solid answer from him, or at least a contact from the housing/PCS department from wherever you plan on being stationed or deployed.
  • zingo
    zingo Posts: 11,258
    edited April 2008
    Just bring it with you; I'm sure your barrack at basic could use a little HIFI!
    I have some of my equipment (speakers and electronics) in a self storage place that isn't climate controlled, and I have had no problems with it there. Granted, there aren't too many weather extremes in the Seattle area, but a great experience none the less.
  • SolidSqual
    edited April 2008
    MikeC78 wrote: »
    I should clarify. I'm joining Air Force National Guard. So, I will be serving here in Indy one week a month two weeks a year after Basic and Tech Training.
  • woofiepaws
    woofiepaws Posts: 224
    edited April 2008
    Do you have family that could take valuables while your are in training?
    We did two years on Okinawa and left the really valuable stuff with our parents. Some went into storage care of the Navy and came out OK, but this was in San Diego where it just gets hot, not wet.
    16 years in the Navy and so far no PCS horror stories. Some near misses however!
  • MikeC78
    edited April 2008
    I can't give you solid answer, you really need to ask your local office. If I'd have to guess, I think you might be SOL on getting storage through the guard, I believe that's going to be something you're going to have to cough up for the moment.
    I personally never put anything in storage before I joined, as I used my parents house. However, I did put my stuff in storage when I was in San Diego, but it was all out of my pocket, and I deducted it from my taxes. Dealing with the military, or getting compensated is a process and you'll find out, a definate pain in the rear.
  • SolidSqual
    edited April 2008
    MikeC78 wrote: »
    I expect to pay for storage myself. I just want piece of mind fromm some of you who have gone before me. I hate leaving my stuff, but I'm not going to let it govern my decisions in life. Leaving my stuff with the family is out of the question because they live too far away.
  • MikeC78
    edited April 2008
    woofiepaws wrote: »
    Damn, 16 years in the Navy... I could barely take 5!:eek: You a Chief yet?:p
  • MikeC78
    edited April 2008
    SolidSqual wrote: »
    To tell you the truth, I just Googled storage places in my local area and went from there. The storage company I went with changed hands three times, and everything turned out just fine. I actually went with a moving company internal warehouse type of storage, made things easier for me when it was time to PCS. Depending on how much stuff you have, a small personal store yourself will be just fine, and I think there is the option of climate control if you'd like.
  • steveinaz
    steveinaz Posts: 19,546
    edited April 2008
    Mike
    When I had an assignment in Turkey, I stored about 70% of our stuff at a storage facility for 2 years. Everything was fine upon our return. I did cover all electronics in doubled-up hefty bags before boxing (just incase of water), and you generally need to consider what type of temps the stuff will be subject to, and pack accordingly. If your storage room doesn't have them, pick up some pallets--it's best to keep your stuff off the ground if possible. Clothing, canvas, stuff that can rot/get moths, etc; buy some of those vaccuum storage bags--they work very well. Of course make sure everything is dry/clean before packing, and I'd recommend wrapping all of it in hefty bags.
    Hope this helps.
  • SolidSqual
    edited April 2008
    steveinaz wrote: »
    Mike
    Hope this helps.
    This is good advice. I am going to pack my electronics like they are being shipped to China on an open bow boat.
  • TroyD
    TroyD Posts: 13,124
    edited April 2008
    If you are going to Basic/Tech School....I don't think that you have any entitlement to gov't storage.
    That said, anything stored at gov't expense is going to sit in crates in a contracted warehouse that will NOT be climate controlled. All in all, it's probably safe enough but I've also heard the horror stories as well. There really is no need to insure anything stored at gov't expense as all claims will be adjucated by the military...so a private insurance company isn't going to do any good. DO make sure that you inventory and document what you store though.
    The rules for ANG is different but I'm pretty sure that all you are entitled to under the JFTR is transportation for you back and forth to Basic/Tech school to your home of record.
    BDT
  • sucks2beme
    sucks2beme Posts: 5,691
    edited April 2008
    MikeC78 wrote: »
    ? Something change? Uncle sam doesn't store anything. You want to keep it, you store it. If it does't fit in a seabag, you'd better be wearing it as far as they care. I left it all at home. And my brother swiped most of it.:mad:
  • TroyD
    TroyD Posts: 13,124
    edited April 2008
    Actually, the rules are the same for all the branches. The governing directive is the JFTR which applies to all branches.
    In certain cases, the gov't will store your property at gov't expense....in this case, I don't think they will.
    BDT
  • sucks2beme
    edited April 2008
    TroyD wrote: »
    BDT
    The only time they ever stored anything was when I came back stateside. They will ship up to a certain amount(by weight) and store it for a short time until they can be delivered to your new location.
    They did store all my stuff that was on my person during boot camp.
    And, as always, the DI was quite willing to "put my **** in a bag".
    I don't think he meant storing it!
  • obieone
    obieone Posts: 5,077
    edited April 2008
    I saw the Navy ship some POV's back from Hawaii. Strapped 'em to the main deck.:D I don't think that fullbird with the red Corvette was anticipating HIGH seas:D By the time we pulled into SanDog, those cars were in need of SERIOUS detailing:eek:
    treitz3 Posts: 20,119
    edited April 2008
    I have a lovely, smoke free, climate controlled living room that can house your gear free of charge. Really, I do. ;)
  • bassaholic
    bassaholic Posts: 315
    edited April 2008
    SolidSqual wrote: »
    Well obviously you're gonna need a place to live. Keep your stuff there
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
  • George Grand
    George Grand Posts: 12,256
    edited April 2008
    It appears to me you are enlisting in the Indiana Air National Guard, not the "Air Force" National Guard. There's a difference. The "AF" National Guard doesn't exist. It might prove helpful to know exactly which organization you are throwing in with.
    Good luck with everything man! And as a Guardsman you'll find you are entitled to about 1/30th the services that active duty folks get (except the getting shot at part). They're not going to pay you squat for anything regarding storage or transport of your goods.
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2008
    boy, I hope George is wrong, but I got a nasty feeling he aint. I wouldnt know
    good luck Solid, and watch your arse
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • SolidSqual
    edited April 2008
    This is true. But, they will pay for my student loans and allow me to continue going to law school. Also, I'm enlisting as an intelligence officer which gives me security clearance. This will help me break into the CIA eventually.
  • obieone
    edited April 2008
    SolidSqual wrote: »
    Um, JMO, but you might want to rephrase that last statement:p
  • SolidSqual
    edited April 2008
    obieone wrote: »
    No . . . they are watching. They know I'm coming.
  • George Grand
    edited April 2008
    You go ahead and take them for all the bennies you can. Let them send you to every school you can stand also while on duty. Might beef up your resume afterword.
    For what it's worth, I've had a Top Secret since 1978. More of a pain in the **** than asset.
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2008
    I would have the family keep it or store in a facility and have them come out every week or so to air the place out. From there you will be ok. If you ever decide to go active make sure you insure your gear through a renters insurance or something. Gov packers could and will care less about your stuff during moves, and TMO processes take forever.
    After youre done, turn around and work for the gov as a contractor, thats where the money is. Trust me I know firsthand.
  • Face
    Face Posts: 14,340
    edited April 2008
    I can break in your EP CS2's for you. ;)
    Stay safe man and good luck.
  • SolidSqual
    edited April 2008
    You're the first to tell me that. I have a whole slew of family members and friends who have pursued various intelligence careers and are extremely happy doing so.
    If you don't mind me asking, why do you consider it a pain?
    edited April 2008
    My uncle John shares the same thoughts as George.
  • daboyz
    daboyz Posts: 5,207
    edited April 2008
    I ain't far away from ya, I'll babysit your gear. Maybe It'll be good for a RAS meeting.
  • steveinaz
    edited April 2008
    SolidSqual wrote: »
    The 5 year updates are a PITA, make sure you keep all your old stuff for reference. I could be wrong on this, but I think now you only have to go back 10 years for the updates...
