Quick question re: RTI8 settings. Ignore after 3 replies!
Opinions:
RTI8 mains used with B&K 4420: Keep them at small speaker setting, or large?
I haven't tried yet to see what it sounds like. Am hoping for some expert advice:
IE: am I loosing anything, will I gain anything, will I make matters worse?
Thanks in advance.
Thanks in advance.
Post edited by BeRad on
I like it Small for HT. More cleaner sound.
.....2~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
.....3~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Ignored
Are you running a sub? If not, go LARGE."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Face: It's in my sig. :P
Why are there more than three replies??
