Velodyne sms 1
toddco
So i opened my new SMS 1 and set it up per instrose and the damm thang wont AUTO EQ. It will play the manual tets tone and i can ajust it but when i Try auto eq pressing 321 it will play the same test tone 3 or 4 times and will turn itself off and on 2 or 3 times and go back to the main screan. Any ideas?
brand new in box. Thanks Todd
RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
PHILLIPS 42" PLAS. 1080i
Monster 5100 SS
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
Monster 5100 SS
Post edited by toddco on
Try calling tech support of velodyne
The easiest way to work with the SMS-1 is to use the Outlaw Manual. Its goes into more breakdown of the unit itself. Follow my link, and go from there.
http://pdf.outlawaudio.com/outlaw/docs/sms1guide.pdf
I use the SMS-1 myself and it performs outstanding in my dual sub setup.Shoot the jumper.....................BALLIN.............!!!!!
Definitely. I vaguely seem to remember this problem. Just skip the auto EQ and do the manual. It's better anyway. I seem to remember that if you do the Auto after you have tried to manually EQ that this happens...? I could be wrong. It's been a while.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Have the outlaw stuff and i called Vell..Tech, What a dick this guy answers the phone Hello Hello.NO prof... treatment at all. I was doing every thing wrong and im an **** for calling. This was how i was treated anyway. And if i am doing everthing wrong & i could be, you dont treat people this way. I will never buy anything from Velodyne because of this Fu..... **** hole. Im glad i got the sms from Audgone.RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
Monster 5100 SS -
Do you have the proper hookups [May be the issue]? That would be the place to start. Would you like a diagram, simplified?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
That's a shame you had a bad experience with Velo tech support. I had the exact opposite experience...they went out of their way to explain things to me & they didn't mind answering any question I had regardless of how dumb it might have been. I suggest you give them another shot. We can all have a bad day!
