Plate amp or Amp One?
gwh
Which amp would be the best choice to power a 4ohm passive sub?
PSW450 Plate Amp
High current power amplifier
Power Output 150 watts Continuous Average Output
Dynamic Power Output 300 watts
Audiosource amp one:
Specifications: *Power output: 80 watts per channel @ 8 ohms, 100 watts per channel @ 4 ohms, 200 watts bridged mono @ 8 ohms *Total harmonic distortion: <0.04% *Frequency response: 20-20,000 Hz *Signal to noise ratio: 110 dB
Large torrodial power supply
2 ohm stable
Thanks,
G
PSW450 Plate Amp
2 ohm stable
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
Plate.
The Amp One is stable bridged to 4 ohms, but it's more geared to SQ and the wiring will be an eyesore. Slap a plate in there and be done. -
I believe I checked with Polk several years ago about using the PSW450 plate amp for a DIY project and they advised against it because of the EQ built into the amp.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
I wouldn't run the Amp One bridged into a 4 ohm load...I also wouldn't use the Polk amp. Rythmik makes several nice plate amps with variable rumble filter settings. I'd recommend the 350w amp. I used it on a DIY project and enjoyed the heck out of it.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Sounds like the vote is for neither:).
I own both amps and for the time being I need to power up a passive SVS with one or the other. I guess I could let my ears be the judge.
I'm hoping someone can come in and lay a lot of technical jargon on the matter and make me see the light on which would be the best choice for now.;)
Thanks for the replies so far.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Im here to brag on either of the plates from parts express the Bash 500 is nicely priced and the Hpsa 1000 is too. The Bash amplifier stunned me at how it rocked two 8ohm 12s of mine. for 249.00. The 1000 is impressive but it has a slight buzz at very low volume which I took care of. But the bash didnt have this!:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Going with the Polk plate amp for now appears I have an amp 100 instead of the amp one.
Yeah I missed those two zeros somehow:o.
Apologies for cluttering up the forum.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
The amp one is actually called the Amp One/A.
technical jargon and what your ears like is diff things , some specs like dampening factor and headroom make a sound differance , better signal to noise % will get a cleaner sound .
But you need better speakers and a trained ear to know the differance .
A lot of people think louder is better .
You are aware a plate amp has a crossover and most externall amps dont ?Sounds like the vote is for neither:).
G -
Have you looked at the date of the last post?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
