Can i fix a driver that is stuck?
Jacob
I have an older pair of Monitor 7C's Recently one of them seized up. If try to move it by hand it has no give. Is there a way to fix this or do i have to replace it.
Jacob
Jacob
Post edited by Jacob on
Hi:
I would replace it. If it seized up once it probably will again.
Gary -
What Gary said, do it.
Cheers,
I just had one do the same thing and am replacing it.....
TroyI plan for the future. - F1Nut -
Thanks you all
I will order the replacement and continue to enjoy my Polk sound.
Jacob -
If it siezed up under normal use, replace it...if it took a hit (dropped) take the driver out, and tap on the ceramic part of the magnet gently with a plastic mallot ot the likes to reallign the motor structure slot around the voice coil assembly. Depending on the circumstances, it can be done.
We've fixed and replaced 'em.
