Cartridge Alignment
del44
del44 Posts: 686
edited April 2008 in Electronics
When I first installed my cartridge, I just lined it up by eye. Well, I was way off. I found a site where you can get a free copy of a cartridge alignment tool. I would imagine most everyone here has one, but if you're like me and need one HERE it is. I thought it worked pretty good. My top end really came alive.
Post edited by del44 on
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2008
    Cool, thanks dude (or dudette).
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited April 2008
    I have downloaded that before but I have not been able to get the hole punched in right to put over the spindle. Any suggestions?
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • del44
    del44 Posts: 686
    edited April 2008
    I used and exact-o (sp) knife. But I may try a bullet cartridge and a hammer next time. Maybe a 38. cal. I think a 22. cal might be a little small. I need to make sure it's been fired.:eek:
  • MillerLiteScott
    edited April 2008
    I tried a hole punch but it is nearly impossible to get it centered and it is to small. I will try the exacto knife but I think it would be hard to get that perfect also.
  • doctor r
    doctor r Posts: 837
    edited April 2008
    If you use a hole punch - turn it upside down so you are looking through the hole. You can see the crosshairs correctly and can easily punch the hole centered. The punch size could be a factor but you will be very close.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited April 2008
    del44 wrote: »
    Thanks. I can't even describe the difference but it is night and day. Kind of like buying a completely new cartridge or turntable and being blown away at how much better it sounds. All this on a techniques sl-1800 and a AT440MLa cartridge.
