restoring vinyl
honda cber
honda cber Posts: 267
edited April 2008 in 2 Channel Audio
heya folks. just "found" about 100 lps. it looks like quite a few got wet, and some of those, very wet. as youve guessed, the jackets are fairly destroyed, and a few of the lps have residue, etc. some of them are going to be beyond saving, but i think i have a fair chance with the others.
question 1:
what is the best way? i was using lukewarm water with dishsoap in it to clean (with the pads of my fingers) the grooves, then rinsing thoroughly under the faucet.
question 2:
since the jackets are destroyed, where is a good place to buy sleeves? preferably the kind that have mylar or plastic inside of a card-stock sort of shell. paper sleeves are another option. any ideas? i will need bulk (at least 50).
hey, they were free, and worth the effort.
TIA,
a
gear list:
1 down, 4 up....
Post edited by honda cber on
