Hooking up my AVR-Does This Make Sense
double d
double d Posts: 23
Firstly, hi to everyone, been reading this forum extensively the past couple of weeks, I decided to buy a 5.1 system. Have a question for you, it may seem silly but I have to ask. So I wanted to buy a surround system as I just purchased a 46" tv, almost bought a HTIB but after much research found out that wasn't the way to go, decide to buy POLK instead as many good things were said about Polk on various internet forums.
I couldn't spend a lot of cash but wanted to buy something that would sound good. Bought a HK 147 receiver, 4 R 150's, a CS1 center and a PSW 303 sub.
My question is as follows; I know receivers are designed to use both audio and video however my HD tv picture is perfect, why would I want to hook up any video to my receiver? I'm thinking that all I would have to do is hook up 2 optical audio cables, one from my cable box to the reciever and one from my DVD player to the receiver as well. I would also be using a HDMI connection from the DVD to the tv. All I really bought the receiver for is to power my surround system. Would this work or would anybody have any other ideas how to simplify my connections? Hopefully I'll be on here often, already have the upgrade bug but will have to wait until I have more spare cash. Thanks in advance.
Post edited by double d on
  • greg2350
    greg2350 Posts: 544
    edited April 2008
    Should work fine thats how I have mine setup.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • danger boy
    danger boy Posts: 15,722
    edited April 2008
    you don't have to use your AVR for video at all.. just continue to use it as you are... be sure to run the auto calibration with a microphone if your AVR has one.. it will make setting up the speaker levels really easy.
    good luck and welcome to club Polk !
    PolkFest 2012, who's going>?
  • double d
    double d Posts: 23
    edited April 2008
    thanks, that's what i was hoping, haven't got it yet but will try when I do.
  • seeclear
    seeclear Posts: 1,244
    edited April 2008
    The only reason I can think of to run the hdmi through your receiver would be to have multiple inputs (like DVD + HD cable/satellite) with just one cable to input to the TV. If you only have DVD to run hdmi to the set, or if the set has multiple inputs, you have no need to run hdmi through the receiver.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2008
    If you are into Home Theater and Hi Def and you want to take advantage of the audio capabilities in Blu Ray or even HD-DVD, then you may want to reconsider using your AVR for video and audio because of how audio content is passed over HDMI.
    If you only use optical connections to your avr, you won't be able to send the newer lossless audio streams such as TrueHD or DTS HDMA or even multichannel PCM, because optical will not support these - it must be over HDMI.
    And because the video AND audio content is sent over the same HDMI connection, the 'chain' would normally be from Blu Ray player to AVR to HDTV. The audio content is then either decoded or sent as is (PCM) thru the AVR to your speakers while the video content is stripped off and sent to your HDTV over HDMI.
    If your player has separate analog outs for 7.1 or 5.1, then you may be able to use your planned configuration, but, despite HDCP and the anamolies of HDMI, it is more flexible than separate connections and consolidates the number of connections between gear.
    Just tossing that out for consideration.
    Erik
