Matching PSW1000 with RT3000 subs
dpowell
dpowell Posts: 3,081
I recently purchased the PSW1000 from Bronson here on the forum and have added it to my RT5000 setup. I have it configured now to where it blends quite nicely but I have a question. Here is how I have things configured now:
On the AVR, speakers are set to Large
RT3000 subs are connected to the L/R line-level outputs and x-overs set to 80hz
PSW1000 is connected from Sub output on AVR to L input, not LFE input and x-over set to 60hz. This is where it seems to blend best.
When I set the speaker size on the AVR to small, things don't sound good as the PSW1000 seems to become over-bearing and to 'directional'
What I'm curious about is the PSW1000 has a volume control that goes to 11. I have it set at about 1 to 1.5 and it sounds really good. It blends and I don't get a sense of any directional bass. Any louder than that and it become too loud for the rest of the system for music. On movies a 2 does really well and at 3, the house begins to vibrate.:D
Does this setup seem normal or am I missing there being a reason why I don't seem to need 90% of the output capability of the PSW1000? Maybe because the RT3000's are producing a good portion of the bass signal range, the PSW1000 just has to fill in the very bottom?
Post edited by dpowell on
  • karpiel666
    karpiel666 Posts: 173
    edited April 2008
    Not sure if this is any help, but I normally run my SVS at mark 2 of 8, and I sometimes find that to be a bit much.
    dvd player: samsung DVD-HD850
    receiver: Denon avr5700
    center: polk cs400
    fronts: polk rt800i
    surrounds: Unknown Polk monitor? series.
    sub: svs pb12 isd/v
    tv: 46 inch samsung
  • juliusbk4
    juliusbk4 Posts: 36
    edited April 2008
    Ive found that the PSW1000 sound even better when its placed inside a cabinet in front of the room. Not sure why this is, when I demo that box it sounded really good at low volumes placed inside the wall cabinet. I compared it to a Martin Logan Descent sub and a high end focal sub ive never seen before and the polk really sounded just as good if not better than those two. The focal sub was like 3 - 4k too. Good buy.
    Sony KDSR70XBR2 70" RPTV :D
    POLK LSi-25s (Front)
    POLK LSi-FX (Surround)
    POLK LSi-C (Center)
    POLK LSi9s (Rear)
    Dual JL Fathom F113 :eek: (Sub)
    Onkyo TX-NR5007 (Receiver)
    Oppo BDP-83 (Universal Player)
    Toshiba HD-XA2 (HD-DVD/DVD)
    XBOX 360 Elite
