Removing Shift Knob
Early B.
Early B. Posts: 7,900
edited April 2008 in Custom Fabrication
Does anyone know how to remove this shift knob? It's a 1998 Mercedes C280 and I want to change it out. There is a screw on the top. I removed the screw, but now what?
Here's a pic...
"God grooves with tubes."
Post edited by Early B. on
  • Face
    Face Posts: 14,340
    edited April 2008
    I'm not familiar with Benz, but on GM, if you pull the shifter all the way back, there will be a U shape clipped on the bottom front of the knob.
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2008
    I've never seen a car with four front-left windows. Cool.
    SOPA
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2008
    It's one of those optical illusions Ricardo, I see 4 front right windows, it means I'm more creative than you, or smell better than you or something.
  • Jstas
    Jstas Posts: 14,977
    edited April 2008
    Hacksaw will take it off ina jiffy!
    Expert Moron Extraordinaire
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2008
    My shift knob just twists off, did you try twisting it?
  • Jstas
    Jstas Posts: 14,977
    edited April 2008
    My shift knob used to just pop off on the 3-4 shift if I was rowin' the gears pretty hard.
  • Early B.
    edited April 2008
    bobman1235 wrote: »
    I tried twisting, pulling, yanking, and tugging, and I ain't talkin' about wackin' off.
  • bobman1235
    edited April 2008
    This is for a different model but maybe the procedure is the same :
    if you check for shift knob you'll see a silver piece on the shift nob. turn that silver piece counter-clockwise, it's like a ring. once that's done. just pull the shift up and the shift knob should be off. don't twist the whole shift knob as that will cause the shift to be loose.
  • exalted512
    exalted512 Posts: 10,735
    edited April 2008
    Like said above, either the bottom black part should twist off or the tan part should twist off...or a hacksaw.
    -Cody
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited April 2008
    exalted512 wrote: »
    -Cody
    are we still talking about wackin off?
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Deadof_knight
    Deadof_knight Posts: 980
    edited April 2008
    Look at the lower ring I have a shift knob that this ring unthreads down which uncovers a set screw then you can unscrew the knob like their taking about ...
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
