Belden 1505A/1505F cable difference?
SlowcarIX
anyone knows what the difference between the 1505A and the 1505F cables?
Thx!
Thx!
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
I believe 1505F is stranded core and 1505A is solid core.
thx all...
sound/video wise...which might be better wire?my 7.(1x4) HT setup
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
I tried 1505F when I made my own ICs and compared them: http://www.polkaudio.com/forums/showthread.php?t=64302&highlight=star+quad
The 1505F was fine, but not my first choice. -
The 'A' has the 20 ga solid center conductor and a hair less capacitance. Both have a PVC outer jacket that can be stripped off.
1505A Belden specs
1505F Belden specs
89259 Belden specs
I wish there was an 89259 with solid 24-28 gauge center. It has the teflon outer jacket. -
i got 4 x 2ft canare/1505A...https://www.cablesforless.com/index.asp?PageAction=VIEWPROD&ProdID=13942
i need 3 x 2ft canare/1505? more for 7ch hookup and wondering if i should switch to the "F" cable...
i believe BJC uses 1505F...my 7.(1x4) HT setup
Buttkicker
With that little amount of wire, it wouldn't hurt to try it out and see if you hear a difference. The only real difference is the stranded core and braid-braid vs. braid-foil shielding.
