just bought rti12's but which amp?
quezwood
quezwood Posts: 10
edited April 2008 in Speakers
Hi All.
My first post but have been reading these boards for some time.
I just purchased rti12' s for the front and a csi5 for the center.
I also just upgraded my receiver to the Denon AVR-987 (same as AVR-2807). I know the AVR is rated at 110 wpc but I have the opportunity to pick up an Emotiva LPA-1 used for $250 to $300.
The LPA-1 is rated at 125 wpc.
1- Am I going to feel the difference between the LPA-1 and Denon??? I have searched around and could not find a definitive answer.
2 - I know AVR's wpc are usually overstated but will the difference be enough to justify the purchase of the LPA-1?
3 - Is the LPA-1 sufficient enought to push the rti12's or should I looked for a used NAD, Adcom, Rotel, etc. instead for $350 to $500 that can do 200 wpc???
Thanks everybody for the help!
Mains - Polk RTI-12 (cherry)
Center - Polk CSI-5 (cherry)
Surrounds - Polk FXI-5 (black)
LFE Sub - Velodyne DPS-12
Main Amplifier - Carver TFM-35x
AVR - Denon AVR-987
Post edited by quezwood on
  • ben62670
    ben62670 Posts: 15,969
    edited April 2008
    Welcome to club Polk.
    If you have been reading the posts for a while you should know your answer. This same question has been beaten to death for the last 3 months solid. There isn't a day that goes by without this topic being debated. Check the new post button out, and the search button. Yes the amp will kick the **** out of the Denon, or nearly any other receiver out there.
    Ben
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2008
    I believe more is better & if you can get your hands on a 200wpc amp you will like it alot. Or you can go for the ever nebulous undefined, un-named 'quality' over quantity lesser watt amp & hope you notice a difference.
    Get a used Rotel, Adcom, Parasound, Nad, Sunfire, etc from Audiogon & you will be good to go. I had a Parasound HCA1500A that really rocked & showed me what my 18 yr old speakers are capable of!
    All of these companies put out good 'quality' products.
    Good luck.
  • el_General
    el_General Posts: 9
    edited April 2008
    Just curious, how much did you get the 12s and csi5 for??
    The sound advice (tweeter) here in orlando has RTi12s for $238.40 EA and the CSI5 for $158.40 in cherry, if i hadn't already got my current speakers i would've jumped all over these and saved some $ in the process :mad:
  • chargerman426
    chargerman426 Posts: 419
    edited April 2008
    Just as a suggestion you might want to look at the carver stuff. i got my carver m1.5t which is 350 watts rms at 8 om for about 350 shipping. there is less powerful stuff from carver but at about a dollar per watt.
    If life had more tubes it would be a lot smoother.
  • crd2002
    crd2002 Posts: 174
    edited April 2008
    it will be like night and day if you get a dedicated amp
    Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
    2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
  • quezwood
    quezwood Posts: 10
    edited April 2008
    el_General wrote: »
    That's exactly what I did :)
    Sooo, is the consensus that the emotiva lpa-1 would not be worth the upgrade over my Denon avr-987???
    Thanks everybody for the feedback so far.
    AVR - Denon AVR-987
  • greene1968
    greene1968 Posts: 126
    edited April 2008
    i bought the lpa-1 to use with my onkyo 805. It did make a difference, but i kinda wish i would have gotten the xpa-5 which is 200 wpc. Either way, emotiva is a great company to deal with
  • BrettT1
    BrettT1 Posts: 560
    edited April 2008
    You need more power. Get the best amp you can afford.
    Put 500w a channel to 'em.;-
  • steveinaz
    steveinaz Posts: 19,538
    edited April 2008
    There's a nice Soundcraftsmen A2502 (125w/rms) in the Flea market.
