FS: AMC Dac 8
RuSsMaN
RuSsMaN Posts: 17,986
edited April 2008 in For Sale (FS) Classifieds
AMC DAC 8 D/A Converter
AMC DAC8 - 4 Digital Inputs -- 1 Optical + 3 Coaxial, 2 Outputs -- 1 Digital (BNC) + 1 Analog
APPLICATIONS AND FEATURES
The AMC model DAC8 was designed to meet professional quality standards for Digital to Analog signal conversion.
The highest grade of components are used throughout with critical components selected for the sonic performance.
Double sided, through hole plated, Printed Circuit Board.
The AMC model DAC8 provides 4 selectable S/PDIF inputs, 3 coaxial and one fiber optic.
The DAC8 can automatically lock to either 32 KHz, 44.1 KHz or 48 KHz digital sampling rates for use with laser disc players, CD÷Õ or DAT machines.
The AMC model DAC8 uses the latest generation of bit stream continuous calibration ultra-linear Digital to Analog Converter, with inherently low jitters.
For those users with digital recording capabilities, the DAC8 has a digital output for connection to DAT, MD or DCC type machines, thus maintaining the ultimate in recording quality
The AMC DAC8 provided an accurately calibrated output level in accordance with the EIA (Electronic Industries Association) recommended standard of 2 volts. This output level provides the best possible performance particularly for home theater users.
The fiber optic input provides electrical isolation from Laser Disc players, thereby avoiding conducted interference from Video sources into the Audio chain.
The superior performance of the DAC8 will provide not only improved technical specifications to your system, it will also significantly upgrade its sonic qualities.
SPECIFICATIONS
THD 20 Hz - 20KHz and SMPTE IMD
0.005% A-WTD at 2Vrms
Signal to Noise Ratio 104dB
Output Level 2V rms
Frequency Response 20 - 20 KHz, + -0.3dB
Channel Separation 90 dB
Resolution 18 bits
Linearity up to -90 dB +/-0.5dB
Input automatically locked to 32K, 44.1K and 48KHz SPDIF digital signals.
PHYSICAL PROPERTIES
Dimensions (W x H x D)
430 x 82 x 300 mm
Net Weight
4.2 Kgs
Sold in full working order, minor marking on top from use, not abuse. Facia is clean. Outstanding sound and features for twice the price. I've been using this in conjuction with an AMC cd player as transport only. They made this gem from 1996 to 2004, with an MSRP of $249. $140 shipped.
Post edited by RuSsMaN on
  • zingo
    zingo Posts: 11,258
    edited April 2008
    I have this DAC and recommend it; it cannot be beat for the price.
  • danger boy
    danger boy Posts: 15,722
    edited April 2008
    how would this compare to my CAL tube DAC?
    PolkFest 2012, who's going>?
  • RuSsMaN
    edited April 2008
    Which CAL do you have?
  • danger boy
    edited April 2008
    RuSsMaN wrote: »
    Alpha
  • RuSsMaN
    edited April 2008
    Comparable, I'd probably give the edge to the Alpha.
  • sda2mike
    sda2mike Posts: 3,131
    edited April 2008
    i've got one too....made my sony carousel mellow out:cool: i recommend it;)
    heiney9 Posts: 25,432
    edited April 2008
    Use one in my computer system. It does a nice job.
  • RuSsMaN
    edited April 2008
    This is a.....
  • Gadabout
    Gadabout Posts: 1,072
    edited April 2008
    PM sent
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
