Newbie lsi9 + marantz
Hi everyone:
I've just bought a pair of lsi9 and i was wondering if the Marantz pm7001
would have enough power to drive my speakers.
And if you got a better suggestion of another stereo amplifier will be very apreciated (less than us$ 1.000):o
thank you.
marantz specs:
PM7001 Integrated Amplifier | $599.99
The PM7001 stereo integrated amplifier is the perfect solution for the audiophile seeking uncompromising musicality with flexible operation.
* 70Watt/Ch Into 8 ohm /100 Watts/Ch Into 4 ohm
* High Speed Instantaneous Current Supply Power Amp Design
* New Power Stage construction
* Current Feedback Topology Volume Amp and Power Amp
* On-Board HDAM® SA Technology
* High S/N ratio and Channel Separation Input Buffer Circuit
thank you.
marantz specs:
Post edited by albatross on
That's a solid integrated amp. I've listened to it with a lot of different speakers at an audio store in Des Moines IA. With the high current design it should be adequate for the LSi9's unless you are in a huge room or want to listen at high volume levels.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
^ what that dude said.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
thank you. On my way to buy one right now
No, don't do it.The Escape Pod Equipment
Samsung HL-S5679W
Sony STR-DA5200ES
Outlaw 7125
Sony 60GB PS3, Blu-ray Disc
TiVo Series 3 HD
Universal Remote Control MX-900
Polk Audio LSi9 ebony, fronts
Polk Audio LSiC, center
Polk Audio LC65i in wall, surrounds
SVS PB12-Plus Piano Black
Outlaw PCA interconnects
BetterCables for HDMI & SUB
Master Bedroom
Sony KDL-46XBR4
Sony 40GB PS3, 2nd Blu-Ray Disc
Polk Audio i-Sonic -
That Marantz is on the anemic side when it comes to 4 ohm loads.
If you already have a preamp or have a receiver that has preouts, take a look at the Parasound A23. A much more solid amp, and it wont break your bank. -
I've heard that little integrated run Magnepan 1.6's, and it did a fair job. You can't put it in the same class as the Parasound Halo line, and it isn't even close to being in that price range. It's a good solid integrated amp that you could start out with for the LSi9's, and you're going to do alright on reselling it when you want to move up to something like the Parasound Halo line.DKG999
What's considered a good price for that Marantz?
I have seen them new for $399 + shipping, in the past. Not a piece of gear I keep tabs on, but happen on them when searching for other things.DKG999
$399 is definitely a good price for such a nice integrated.:)
Magnepans are probably easier to drive than anything from the LSi series.I've heard that little integrated run Magnepan 1.6's, and it did a fair job. You can't put it in the same class as the Parasound Halo line, and it isn't even close to being in that price range. It's a good solid integrated amp that you could start out with for the LSi9's, and you're going to do alright on reselling it when you want to move up to something like the Parasound Halo line."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Do you own Magnepans? I do. I also own LSi's. Wishful thinking on the "probably".DKG999
They're right in my sig.
Maggie impedance curves are usually nice and flat at 4ohms, meanwhile a LSi9's dips down to 2ohms.
Anything else you'd like to add?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
The 1.6's are a little different animal than the MMG's. I can drive MMG's nicely with my NAD receiver. The LSi9/7 have seemed much easier to drive in my experimentation than the Magnepan 1.6's. That same NAD receiver will drive the LSi7 nicely, and do an admirable job with the LSi9. It will die on the 1.6's.
Sorry to come off short, and didn't notice the MMG's in your sig.DKG999
Most maggies are similar in design and have the same flat impedance curve.
You may believe your receiver is having a harder time with them due to their less efficient design than the LSi's. When I hook up my maggies, I have to almost use double the volume as I would with my Tannoys to reach my usual listening level."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I don't even factor in the volume setting, I'm refering to sound quality.
Back to the OP's question, I believe the Marantz IA is going to do just fine with the LSi9's within the boundries outlined. You can throw around technical specs all day long, but the LSi's aren't that hard to drive, and I'm pretty much convinced that you can get decent sound with a wider range of amps and receivers than most of the comments here would lead you to believe. To get outstanding performance, and get the most out of them, then you need some good source gear. YMMV.DKG999
^^ I would have to agree that the 9's are not that difficult to drive. My old 70's integrated by Technics (73 WPC) handled them quite well. So do my HK 3480 and Outlaw RR 2150 receivers.2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series -
Exactly. The poster didn't ask if it was the "ultimate" setup, he asked if it would work well. As dkg pointed out, small to med room and moderate volumes, you'll be fine--later down the road if you feel the need, you can get an external power amp.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
