Wall mounting a CSI3 Speaker
schwartznick@ho
Hi, I have searched but can't find any options for wall mounting the Polk CSI3 center speaker. It is pretty heavy so I really don't wany to set it on top of the TV. Anybody with any suggestions, wisdom, or websites. Thanks.
Post edited by schwartznick@ho on
I've got a CSi3 that is wall mounted in my HT setup here:
The mount is from B-Tech:
http://www.btech-usa.com/bt15.html
Works well.
Cheers,
Erik
Very nice set up Eric!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Looks great, thanks for the reply!
