PSW450 Question
crenkar
Recently purchased the PSW450 I ran it dorectly into my SOny ES home theatre and it sounds pretty good. Here is the problem, when I have the sub switched to "look for the signal from the stereo (pardon my lack of terminology) I will occasionally hear a pop as if a surge of power into the sub Almost as if when it picks up a signal to process Is this normal?
Post edited by crenkar on
crenkar, welcome to the forum. To put it simple YES it is normal.
Should just be the amp powering up the sub.:)
