sr speakers in 07 dodge ram
crz28xlr8
crz28xlr8 Posts: 4
edited April 2008 in Car Audio & Electronics
any tips for me in installing these in the 07 ram mega cab,......one set for the front and one for the back. seperate amps for each set. oh i almost forgot they are sr 6500 series 6.5
Post edited by crz28xlr8 on
  • exalted512
    exalted512 Posts: 10,735
    edited April 2008
    To get the most out of them, be sure to make a MDF baffle (coated in something to resist water), as well as properly sound deadening the door.
    Good luck!
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2008
    The SR's come with a 6x9 adapter. I used this on mine. Slap a layer or 2 of Dynamat around it and itll be just right.
  • crz28xlr8
    crz28xlr8 Posts: 4
    edited April 2008
    thanks for the door speaker advice..........now what should i do for a sub? get the polk db 12 " and build it under the rear seats in the mega cab, or put it behind the seat?
  • exalted512
    edited April 2008
    Behind the seat for sure. Plenty of room back there.
    -Cody
  • crz28xlr8
    crz28xlr8 Posts: 4
    edited April 2008
    and finally the amps i bought two fosgates 400 watt 2 channels on sale, will they work the speakers fine?........for a deck i havn't bought anything yet but noticed the new jvc 810 doubledin dvd combo look good.detachable screen/face...anybody try one yet?
  • exalted512
    edited April 2008
    do you have the navigation package? If not, you will have to go to the dealership and buy it, it cost around $100, to fit a double din.
    -Cody
  • dirthog
    dirthog Posts: 124
    edited April 2008
    If it's easy for you to make a MDF ring I suggest it. I used the plastic 6.5 ring and it made noise at higher listening levels and I used a layer of deadener behind it.
    HU: 880PRS
    Front: SR6500
    Amp: Alpine MRV-F545
    Sub: SR124-DVC
    Amp: Alpine MRD-M1005
