amp question
Danac787
Danac787 Posts: 18
edited April 2008 in Electronics
if you have a 5503 amp pushing rti12s and a cs5 front, do you need an amp for the rears? or can you allow your primary amp to push them? thanks.
I have a yamaha rx2700 amp atm looking at a 5503 for some background.
Post edited by Danac787 on
  • Sami
    Sami Posts: 4,634
    edited April 2008
    You should be fine with the Yamaha driving them. I'm assuming fairly small 8ohm speakers in the rear.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2008
    Your fine. Adjust the levels in the setup, and call it a day. If your not satisfied you can add an amp later.
    Enjoy
    Ben
    Ben
