Fuses
Systems
I have a Rockford 200 a4 and an 800 a4. I run 4 gauge power wire from the battery to a distribution block. From the block I have 2 8 gauge power wires running to the amps. My quewstion is the 200 a4 calls for a 30 amp inline fuse and the 800 a4 calls for a 60 amp fuse. I currently have a 60 amp fuse on the 4 gauge power wire running into the distribution block. Do I need to put another 30 amp fuse after the distribution block?
Testing
Testing
Testing
Testing
Testing
Under the hood, put a circuit breaker or a HI AMP fuse, such as 150+ amps.
Run the required fuses in the distroblocks 8" b4 the amp. Use a rellay for the remote wire going to the 2 amps. I here that IT COULD possibly fry your deck.
ALSO-check out that 800a4, it HAS dual power supplies, this means, it gets 2 grounds and 2 positives.
