Windows Explorer issues
daboyz
My windows explorer won't respond when trying to open.:mad::( I've got Vista.
Any ideas?
Thanks, Dave
Any ideas?
Thanks, Dave
Post edited by daboyz on
I assume the IE worked for you before it broke down with this problem.... If it is the case, restore to the point that it worked fine. That is my recommendation.
Okay, windows explorer and Internet Explorer are two different things....But yeah try a previous restore point for starters.Testing
Testing
Testing
