Question on subwoofer hookup
Hi,
I just bought a new amp and set of speakers, and am running into a problem setting them up.
My powered sub has RCA jacks labeled Left and Right, but my Amp just has the one RCA jack for Subwoofer out. My Amp has 2 subwoofer outs, but intended for two different subwoofers (7.2).
I've seen people mention Y connectors, and other people say that's not good.
What would be the right way to hook my Sub up?
My Amp is a Yamaha RX-V663, and my speakers are Polk Audio RM6880
Thanks!
  • Hi-Buy
    Hi-Buy Posts: 110
    edited April 2008
    I'm not an expert however, a Y- cable will work fine or just hook up a single rca to the left input.
    Big thanks to "Neskahi" !
  • Early B.
    Early B. Posts: 7,900
    edited April 2008
    A Y-cable isn't necessary. Just use one of the RCA jacks on your sub and run a cable to the Sub Out on your Yamaha.
    "God grooves with tubes."
  • tfrazier
    tfrazier Posts: 3
    edited April 2008
    Thanks folks. I'll just connect a single RCA cable from my Amp's "Sub Out" to the left channel on my sub leaving the right channel of the sub unused.
    Thanks for your help!
  • jingoboy_78
    jingoboy_78 Posts: 26
    edited April 2008
    Hi,
    I have the same satellite speaker system and I am using a Y cable and it works fine.You can also use a single RCA. If you use a Y cable all you can get is a 3db gain in the sub woofer volume.So if you are using a single RCA increase your sub volume by 3 decibels with the help of your receiver.hope it helps.
    Regards,
    Jingo
  • busterapco
    busterapco Posts: 18
    edited April 2008
    I was told that you get stereo out of the Y cable when plugged into the sub. I have the Y connection wire ($40.00). I do not notice a difference in them from a normal rca plug. Little different on the phasing, but I do not notice if its a bad or good thing. lol
