New Polk LSi15 Owner
jpolz
jpolz Posts: 15
edited April 2008 in Speakers
Howdy folks!
I just got a pair of LSi15's and I'm curious the best way to "tune" them. I'm powering them with a Sony STR-DE1075 in a relatively small room. It's currently paired with a KLH-ASW8-120 subwoofer (yeah it sucks, but it's only temporary).
The biggest question I have is how to set the cross-over frequencies & gain for the treble, mid, and bass ranges. The ranges are:
Treble: 1Khz-10Khz
Midrange: 198Hz-10Khz
Bass: 99Hz-1.0Khz
Each range has a 0-10dB gain.
I fiddled around with them for an hour and I can never seem to get it tweaked just right. Any suggestions or comments? Thanks!
Mains: Polk LSi15
Pre/Pro: Yamaha RX-V663
Amplifier: Emotiva LPA-1
Subwoofer: KLH ASW8-120b
Post edited by jpolz on
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    That's the EQ function of that unit is there's no reason to use anything but the defaults. Reset it and forget it.
    treitz3 Posts: 20,119
    edited April 2008
    My suggestion if you insist on using the EQ part [though I would lean toward not using it] would be to lower the frequencies before you do any boosting of frequencies and even then, move only a minimal amount. If they are strictly gain, follow Doro's advice and go back to default and never look back.
    Congrat's on the speakers and welcome to Club Polk.
  • jpolz
    jpolz Posts: 15
    edited April 2008
    Holy shite!
    I just did a reset back to default settings on the receiver and it sound MUCH better. Something must have been way out of whack from years ago when i first set it up for my old speakers.
    Mains: Polk LSi15
