New Receiver as pre : Onkyo, Denon, Pioneer, or Marantz?
Topper
Topper Posts: 403
edited April 2008 in Electronics
Hi guys!
Am from the world of car audio and still learning the ropes on the Home audio front :).
Anyways trying to come up with a plan for a good system and I know i want to use an outboard amp but can you guys recommend a good receiver that has all the features and won't break the bank (hopefully $400 or so).
What should i look out for? which models should i look into? (reason i only mentioned the 4 are cus they're the easiest available where i am (philippines) :)).
Anyone have the inside scoop on the new gear from these 4?
Post edited by Topper on
  • avguytx
    avguytx Posts: 1,628
    edited April 2008
    With Onkyo, it will be the TX-SR705 before you get into preamp outputs and those "retail" at $799 although you'll see them going around the $600 range or so right now.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2008
    If you're going to use a separate amp, why do you want a receiver as a pre/pro? Why not go straight for a dedicated separate pre/pro?
  • jaysonbarnett
    jaysonbarnett Posts: 257
    edited April 2008
    ONKYO for sure you get more for the money, and for the second place winner DENON
    Audio:
    Onkyo :tx-sr805
    Polk: rti8's
    Polk: rti4's
    Polk: fxi3's
    Polk: csi'3
    Velodyne: VRP 1200
    Epik: Caliber
    Video:
    Panasonic:TH-42PX60U 42"Plasma
    Power Conditioner:
    Monster Power
    : HTS 3600 MKII Home Theater
    Dvd:
    Sony: BDP-350
    Game Systems
    WII
    PS3
  • DollarDave
    DollarDave Posts: 2,575
    edited April 2008
    You should have Harman/Kardon available through their e-bay outlet store. You can purchase either the 435 or probably the 437 for that price and have a fine front-end. After that, your could try accessories4less and grab a Marantz.
