Center Channel Improvement!
MxStYlEpOlKmAn
I am so bored, its the weekend - and I got tired of hearing this horrible hissing noise from a over-shot sound from the center. My center is about 6-7 feet off the floor. So, I took 2 cd cases, and put one under each corner of the center! Worked out great, the sound is aimed pretty much straight at me, and most of the hissing is gone! YAY! and not to mention, i REALLY need to dust!
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
I promised myself
Damn you all! - ATC
I had to do the same thing.. my center was facing out and it needed to face down. I shimmed it at the back with wood, but also used rubber feet to be sure it wouldn't slip. I'd suggest you find something a little more permanent/stable than CD cases. But, pointed in the right direction is certainly a good thing.
Well, mine is also on rubber feet. LOL! The front two feet are catching the top edge of the tv, and the back are on the cds, so i don't think it will slip.Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
i have my center faceing down i have the standard feet in the front and a set of feet off my surounds in the rear that works great
Try those angled rubber door stops. The rubber will keep it from slipping. Just a thought.
thanx for the advice - neone want a 100% dust shirt? if so, i got one going on sale for 90% off! at mx's special ht dust sale!Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
