Polk M 20's or Monitor 50's
hi all
I recently purchased a set of m 20's 3/4 tweeter & (1) 6.5 driver
the cost was 160.00
i can get a set of monitor 50's from amazon for 260 delivered
the 50's have (1) 1 inch tweeter and (2) 5.25 drivers.
Both are 2 -way speakers.
I'll be mixing them with a cs1 or cs2 center channel
The folks at polk say i should stay in the same line (blue/silver cones versus paper cones) the cs series has the blue/silver cones.
After a few minutes he said that they were close anyway.
my room is 14X20 with vaulted ceilings. I'm driving with a 75 watt per channel denon.
these will be my front speakers.
Do you think it is worth it to spend the extra $90.00 for the 50's?
THanks in advance
the cost was 160.00
THanks in advance
