Upgraded my sub, now quick question
dx31698
dx31698 Posts: 13
I had the polk rm6750 system, and today i upgraded my sub to a velodyne VRP1200. I still have the same speakers right now. With the sub that came with the system I used the bass management way to hook it up, plugging the fronts into the sub and then to the receiver. Should I still do that with this sub, or use a subwoofer cable? I'm using a onkyo 705, any info would be great. Thanks
Post edited by dx31698 on
  • PSOVLSK
    PSOVLSK Posts: 5,412
    edited March 2008
    Either way will be fine. I'm sure you already have it hooked up the way you had your old sub...so I'd leave it like that.
  • mark090852
    mark090852 Posts: 1,001
    edited March 2008
    If hooked up that way be sure to have your Onkyo set to "sub=no" and "front speakers= large".
    McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers
  • dx31698
    dx31698 Posts: 13
    edited April 2008
    Ok so i tried both ways, and the way hooking up the fronts into the sub woofer worked well. Then i plugged them straight into the receiver and used a sub cable and the reciever recognized the sub in the calibration mode, but when i would play music and movies there was nothing coming from the sub, so I went back to plugging them into the sub.
    My new question is I just got a good deal on some boston crc7 and cr67 for my center and fronts. Now that I'm using bookshelf speakers instead of the satelites, do I still set my front speakers on large or full band, or change them to a less hz. Thanks
