50 Hz spike / causes?
treitz3
treitz3 Posts: 20,188
I am getting a 50 Hz spike that's high enough to have an audible distraction coming from my sub woofer. What I would like to know from those in the know is...
1 - what are the possible causes?
2 - what can I do to improve the spike without resorting to a graphic EQ continuously in the loop?
3 - Can I change the "Q" in the parametric EQ via the Velodyne SMS-1 to help with this spike?
I had the same thing with the last sub I had which was the Polk PSW1000 and I currently have the spike with the VMPS larger sub powered by a M1.0t, fed by the SMS-1 as well. 12x14' room, V shaped ceilings running the length of the room, VMPS on marble tile over a rug, placed in the left corner of the rig. Here's a couple of pic's....
All equipment must remain on this wall due to space constraints, so I may have no choice but to put up with it. I don't know, that's why I'm asking those in the know.
I have experimented with a 12db drop at 50Hz on the graphic EQ as well as a drop as far as the SMS-1 will allow and the spike is still effecting a flat frequency curve. Before I go **** with anything, does anybody have any advice?
Post edited by treitz3 on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    Room gain can throw things off. If the sub has a parametric setting you may be able knock that bump out. Room placement could certainly help, but I have shared the same space limitations.
    Ben
  • wallstreet
    wallstreet Posts: 1,405
    edited March 2008
    acoustic room treatments should help tame the spike. My B&K has a "notch filter" that allows me to treat the same problem in my room. But I guess that's kind of an equalizer.
  • Systems
    Systems Posts: 14,872
    edited March 2008
    If it is a narrow spike it may be a room mode resulting from the corner placement of the sub.If you can't move the sub to a different location then yes using a parametric EQ set to its narrowest bandwidth and appropriate amount of attenuation should improve matters.I have a similar problem around 50 hz in my room and using a single band of parametric EQ to notch out the peak does the trick.
    Edit.Oops sorry Ben I should have read your post before typing ,you already covered it.
    Testing
    Testing
    Testing
    edited March 2008
    Is a spike 50Hz common?
  • Systems
    edited March 2008
    treitz3 wrote: »
    It depends on the the dimensions of the room and the location of the speaker there in.Google room modes and you should find some good info.
    Testing
    Testing
    Testing
    VR3 Posts: 29,610
    edited March 2008
    Brian has an adjustment you can do to the Larger to adjust for things like this
    Give him an email.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2008
    Tom, were you able to fix the spike? Also, I think it is a VERY BAD IDEA to place your sub amp ON the sub.....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • george daniel
    george daniel Posts: 12,096
    edited June 2008
    take the grills off of those tylers' ;)
  • Early B.
    Early B. Posts: 7,900
    edited June 2008
    TNRabbit wrote: »
    Why?
    "God grooves with tubes."
  • TNRabbit
    edited June 2008
    Early B. wrote: »
    Why?
    ~V-I-B-R-A-T-I-O-N~:eek:
    TNRabbit
    Sunfire TG-IV
  • Early B.
    edited June 2008
    That VMPS sub is built like a tank and it ain't gonna vibrate. And even if it does, so what? Most subwoofers use plate amps and the vibration is not a major factor, so placing an external amp on top of a sub will be even less of an issue.
  • engtaz
    engtaz Posts: 7,672
    edited June 2008
    Wabbit is a friend of Tom's.
    engtaz
    engtaz
