rca and speaker wires
Kinetic
Kinetic Posts: 437
edited March 2008 in Car Audio & Electronics
i was thinking on buy some RCAs and speaker wire..
i have now stinger hyper series RCA, (the blue ones)
and tsunami speaker wire (i buy it on best buy i dont know the model, but its a transparent-red cover, and red coper)
the RCAs im looking for are these:
http://www.knukonceptz.com/productDetail.cfm?prodID=KRY4.4M
the eks model is too expensive and i dont know if its worth it
and the speaker wire i was thinking on these:
on the Karma SS
http://www.knukonceptz.com/productDetail.cfm?prodID=KAR12SS-100 SS Speaker Kable
or the KL3
http://www.knukonceptz.com/productDetail.cfm?prodID=KL3-122-100 Kable
the kasa wire is too expensive, and again i dont know if its worth it.
http://www.knukonceptz.com/productDetail.cfm?prodID=KASA12PRL Speaker Kable
Also what gauge should i buy?
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Post edited by Kinetic on
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited March 2008
    all ur link are broken lol
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • exalted512
    exalted512 Posts: 10,734
    edited March 2008
    Im using the Karma RCAs...or will be. Ive heard many, many good things about them. I have them in my house right now and they seem extremely well made. Very solid construction.
    As far as speaker wire, the Karma speaker wire is good as well. Any more expensive and youre wasting your money IMO. As far as what size, 14awg will be more than sufficient for your full range speakers, and 12 for the subs.
    Im using 12awg for my full range and 8awg for my subs, but I'm a firm believer in overkill times 10.
    -Cody
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    he he sorry, its fixed now
    Z
    Polk Audio SR 6500
    G35
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    exalted512 wrote: »
    -Cody
    oks i could buy a 100ft package of 12 gauge for the comps and sub.
    but whats the difference between "Karma SS" and "KL3" if the price is the same?
    the KL3 says "Audiophile CL3 Rated / UL listed Speaker Wire" that sounds nice, but what does it means really?....
    also the speker wire for cars is the same as the speaker wire for Home?
    Z
    Polk Audio SR 6500
    G35
  • exalted512
    edited March 2008
    Without having time to look, I believe KL3 is their home wire.
    -Cody
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    exalted512 wrote: »
    -Cody
    i already sent an email to knu but i think there is no difference between the home and car wires, becouse knu have the same models for home and car.
    but tell me if im wrong?
    and any other comments about these wires and RCAs?
    Z
    Polk Audio SR 6500
    G35
  • exalted512
    edited March 2008
    There is a difference between home and car wires. Home wires are in a clean environment with a relatively limited temperature range. Car wires have to endure a much broader temperature range and a host of other chemicals that could potentially damage untreated insulation of your wire.
    -Cody
