Landscape in MS Word Anyone?
Early B.
I need to place a single landscape page in the middle of a document that is portrait. Every time I try to do this, Word landscapes the entire document, even if I only highlight what I want landscaped. How do I get 'er done?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Select the text/pages that you want to change to landscape orientation.
On the File menu, click Page Setup, and then click the Margins tab.
Click the Landscape box. In the Preview section at the bottom, select Selected Sections in the Apply To drop down menu.
Then click OK.
Checky good! -
Thanks, petrym!!!!HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
