monitor 50's/bi-amping
aimee
The Mon. 50's have aplace for 2 setsof wire to hook-up and the back of my Onkyo 605 has an area for bi-amping ONLY the 2 front speakers.
A) why is bi-amping even done? better and/or louder sound??
am I taking away from the other speakers if I use this capability?
C) I think the bi-amping hook-up on the 605 is in place of using rear surrounds. Not sure. If so, can only bi-amp if I decide not go w/ a 7/1 system?
I appreciate any insight you may have.
Post edited by aimee on
A: some get improved results by doing this but most people haven't noticed much difference. If you were using two different amps for the highs and lows you would notice more of a difference.
B: You could be possibly taking some away from your other speakers. Your power supply in the Onk is capable of only so much....so if you are trying to put more power to the fronts then it will have to rob it from somewhere else.
C: Yes...you can only do this if you are using 5.1.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
thanks; great answers.
BTW, I'm actually doing a 6.1 (CS-2 for main, 4 mon. 50's for fronts and surrounds, and just once center - CSi25 - as the rear surround(s).)
Only have the center and fronts (and sub) hooked up right now, though. What do you think - good or dumb?? -
I too have tried bi amping with my Denon using the back 2 channels.....I didnt notice any change what so ever.....now when I bought a seperate amp Rotel 993 200 wpc for my fronts and center I did notice an overall improvement in sound. A very nice improvement...
