Bookshelf Max Power
poolshark
poolshark Posts: 10
edited March 2008 in Speakers
I'd like to get a pair of the new RTI A3's. Polk states 'recommended amplifier power' is only 20-125 w/channel. psssssh.
I have a 5 channel Parasound amp at 220 per channel.
Any reason for concern? Or go try to knock myself out.
Post edited by poolshark on
  • tcrossma
    tcrossma Posts: 1,301
    edited March 2008
    No worries. The amp probably has enough muscle to bust the speakers, but your ears would bleed first. Just use common sense and don't try to get house-filling sound from those speakers and you'll be fine pushing them with that amp.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    treitz3 Posts: 19,960
    edited March 2008
    Poolshark, I wouldn't have any concern. Clean power is a different animal from unclean power pushed to clipping. ;)
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2008
    I wouldn't worry about it.
    You're more likely to destroy speakers with unclean, clipped power than with clean power.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    I was testing an amp that I recently fixed with little Ipod speakers. I think they are 25watts max at 4 ohms. I don't care too much if they blow. It would give me a good excuse to build a new pair. Well anyways the amp is an Adcom GFA-555 which puts out 325wpc at 4ohms. I drove the snot out of those little speakers with it. Now take a little receiver, and drive them real hard you are more likely to blow them with it than a big amp. Don't go too crazy, but enjoy.
    Ben
    Ben
