Audio Pro Subwoofer?
kl3640
kl3640 Posts: 32
edited March 2008 in Speakers
I have an Audio Pro Subwoofer (came as part of a set I got a few years back, including Polk SDA SRS 1.2 TL speakers). On the front it says "Audio Pro Made in Sweden" and on the back it has a funky cable connection, sort of a round connector with 5 pins. I can post a pic if necessary.
I didn't have a lot of luck finding the right interface cable on line (I have the cable, but my receiver doesn't accept that type of cable).
Is there a sort of converter cable that I can use to run this circular 5-prong cable in to a modern receiver's subwoofer input port?
Also, I didn't find a lot of data about this item on-line - does anyone here know if it's a good product?
Thanks.
Post edited by kl3640 on
