Amplifier for driving LSi speakers
mightymouse
Which amplifier do you guys recommend for driving the LSi speakers?
There seem to be a couple of LSi speakers up for sale in the sales forum, I am thinking about picking one up. Right now I have a pro Crown amp passed down to me from my brother. Do you guys think it has enough muscles to drive the LSi speakers?
Post edited by mightymouse on
The Crown probably has plenty of muscle, but maybe not the sound quality that will make the LSi's sing. You would certainly be alright giving it a try. From that point any good quality amp, tube or SS, will be good for the LSi's. In a SS amp I would recommend at least 100 wpc in an amp with good dynamic reserves and built to operate at 4 ohms. Lots of previous recommendations if you use the search function.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Again, search and use wild cards (*). Usual recommendations include Rotel, Parasound, B&K, Earthquake, Adcom...im sure I am missing some. I have had good luck with Rotel, Parasound, B&K and Earthquake with LSis as well as others.
Over 200 WPC
Rated to 4 ohm impedance
Everything else boils down to price and personal preference. I love my Sunfire, but many find it expensive. There are a ton of threads on this one so search it out like Gaara said and if you have any more specific questions go ahead and continue this thread.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Depends on which Crown amp you have. An old D150 would be a temp fix. The newer models tend to be more powerful.
It's an old one. My brother was really into that garage band thing for a while. He's no longer into it, so he passed it down to me.
Right now I am using it drive some KLH speakers, sounds pretty good. -
Okay, I'll do a search then. Thanks for all the sugggestions.
