Need Subwoofer Help
AudioFilet
AudioFilet Posts: 235
edited May 2008 in 2 Channel Audio
I need some help deciding on a new sub for my 2 channel system. Right now I am using a Polk PSW12, and it just doesn't quite get it. The system consists of an Outlaw RR 2150 as the main amp, a CD/SACD player and Music Hall MMf 5.1 turntable. Speakers are LSi9's. I listem mostly to blues, jazz and classic rock. Budget is around $800. This is a 2 channel, music only rig, so HT performance is not an issue. I really like the tube type subs from SVS, but I am just not sure it is the best choice for my particular needs.
Can you guys help me out here?!?
2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series
Post edited by AudioFilet on
    treitz3 Posts: 19,992
    edited March 2008
    Have you heard of the Polk DSW lineup for subs? One of those bad boys will blend fine with what you have, just pick your flavor.
  • pearsall001
    pearsall001 Posts: 5,292
    edited March 2008
    For HT I have a SVS 25-31plus cylinder & it literally rocks the downstairs. I tried it for two channel but I couldn't get it to blend in with my mains to my satisfaction.
    So I started looking for a different sub for my two channel system (size was an important factor) I just picked up my new two channel sub...a Velodyne SPL1200R (a tad over your budget though). My initial impression is that I'm going to have a lot of fun with this sub. It comes with a built in EQ system with mic that sends out a burst of 12 low frequency sweeps that literally shake the walls & floor joists. Then adjust the volumn, crossover & phase (with remote, I'm a lazy ****) & enjoy. Talk about fast & musical & a seemless blend with my mains. A more in depth review to follow shortly.
    Now I truly realize what adding a good sub to a two channel mix is all about. I'm diggin it!! The fun has just begun.
    edited May 2008
    Did you end up getting anything?
