Center speaker
donedroolin
When setting up your center speaker and you set the distance in feet from your listening area. Are you suppose to set the distance in the controller a couple more feet away to give it some kind of effect. I thought I read that somewhere. Like if say it is 12 feet would you set it for 15 or is thier a better way.
TV- 52 inch LCD SONY BRAVIA XBR6
TV- 42 inch PLASMA HITACHI ULTRA VISION
AMP- PARASOUND HALO A-51
CONTROLLER- PARASOUND HALO C-2
FRONT SPEAKERS- LSi15's and LSiC
REAR SPEAKERS- LSi7's
SUBWOOFER- VELODYNE DD15
BLU RAY- LG SUPER BLU BH200
BLU RAY- SONY BDPS350
GAME SYSTEM- NINTENDO Wii
MONSTER POWER CONDITIONER
WIRES- AUDIO QUEST and MONSTER
Post edited by donedroolin on
Those settings determine the time delay for when the receiver sends information the speaker, and are used to correct difference in speaker distance from your seating position. The values are relative to each other, so if you doubled every value, you'd get the exact same results. This is not the same as adding a processing effect or something that's going to give you the feeling that you're in a huge hall -- you can use one of the DSP modes of your receiver if you want that type of effect.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Hey tcrossma THANKS for the quick reply , I got it now I think. So I should set them at what they measure from my listenig position.. NICE HT setup you got.TV- 52 inch LCD SONY BRAVIA XBR6
