The UGLY amp.....
treitz3
treitz3 Posts: 20,117
edited January 2009 in 2 Channel Audio
OK, now this has got to be one of the ugliest amps I have ever seen. :eek: Really, for 12K I would expect something that is aesthetically pleasing like the stingray, but THIS?
I'd still like to hear it. :D BTW, who has the most powerful tube amp on the forum? ..............Beauller...........Beauller..........Beauller? Just curious.
Post edited by treitz3 on
    F1nut Posts: 51,996
    edited March 2008
    I like it. It's got that industrial, "Neo-Classic Design" look down pretty well. ;)
    edited March 2008
    It looks like something that belongs in a tank.
    F1nut Posts: 51,996
    edited March 2008
    LOL......more like a laboratory.
  • obieone
    obieone Posts: 5,077
    edited March 2008
    "This is Alpha 3 bravo to base, alpha 3 bravo to base. Our position is being overrun by ugly audio components"
  • analog97
    analog97 Posts: 328
    edited March 2008
    I think that Manley amp is beautiful. Love to hear 500 tube watts push my 1.2 TL's. Beauty is in the eye of the beholder.
    mhardy6647 Posts: 35,229
    edited March 2008
    The aesthetics of that amp work for me. All the Manley stuff shares a certain pseudo-industrial look (including the Stingray).
    Indeed, I wouldn't mind having a pair of 'em... for what they are, they're not even that expensive.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited March 2008
    I wouldn't mind having a pair either bought with mhardy's money.
    edited March 2008
    analog97 wrote: »
    Love to hear 500 tube watts push my......
    THAT's where the real beauty lies.
  • lightman1
    lightman1 Posts: 10,797
    edited March 2008
    treitz3 wrote: »
    Shut up Tom.....:D. If I had the coin, I'd like to give 'em a try. It's what's inside that counts.
    and I'd like to read the specs....;)
    edited March 2008
    * ALL-TUBE monoblock design 10 x KT90EH Electro-Harmonix Russian output tubes
    * High current double 6414W GE driver stage
    * 12AT7EH large plate Electro-Harmonix Russian input tube
    * BALANCED & UNBALANCED inputs
    * MUTE switch
    * TRIODE / TETRODE switching
    * SOFT-START/ EVER-WARM standby mode
    * MANLEY Precision output transformer
    * Factory set for 5 ohms nominal
    * Front panel bias measurement and adjust (hiding under the black insert)
    * Large filter / reservoir capacitors 3800uF x 2
    * Angled rear of chassis provides for easy connections
    * WBT binding posts
    * Input sensitivity: 1V
    * Gain: 32dB tetrode; 30dB in triode
    * Input Impedance RCA: 116 Kohm @ 1KHz
    * Input Impedance XLR: 270Kohm @ 1KHz; 20Kohms @ 20KHz; 38Kohm @ 20Hz
    * S/N Ratio: -80 dB
    * Dynamic Range: 96dB
    * FLAT frequency response: 10 Hz - 30 KHz continuous
    * Power Consumption: 30 Watts in "EVER-WARM"
    * Full power (tetrode): 500W
    * Full power (triode): 275W
    * Factory set for 100V, 120V or 220-240VAC operation for original destination country's mains voltage.
    * Operating Mains Voltage changeable with power transformer re-wiring and fuse value change.
    * Mains Voltage Frequency: 50~ 60Hz
    * Dims: W=19", D=13", H=9"
    * Shipping weight: 82 lbs. each
  • lightman1
    edited March 2008
    OK...but how would it sound? hmmmmm
    edited March 2008
    I'd like to hear this head to head with the Silver Sevens. ;)
  • Face
    Face Posts: 14,340
    edited March 2008
    I'm surprised they're only 82lbs.
  • lightman1
    edited March 2008
    Face wrote: »
    Super-secret, space-age Manley weight saving technology is my guess.
    They look like they could do the job though..
  • venomclan
    venomclan Posts: 2,467
    edited March 2008
    But that is a mans amp. No girly men amps here.
  • Yashu
    Yashu Posts: 772
    edited March 2008
    Can't you read? It says right there on the front "Neo Classical Design"... I mean come on... who wouldn't shell out 12 grand for that?!?! I tried to write those words on my NAD amps with a sharpy and it just doesn't have the same feel... I definitely would have paid 20X more for those words so boldly emblazoned on the front bezel.
    But seriously... I am willing to bet the sound makes you forget about what it looks like. Just turn the lights off... pretend you are making love to some fugly girl you met at a bar, but she makes you feel so good that you forget for a second she is built like a brick shithouse... put a bag over her head and she don't care, she wants to be told how f'ing ugly she is... she gets off to it.
    So, after dropping 12 Gs on that thing, promptly throw it on the ground and tell her she is an ugly ho, and plug her in and listen to her sing, you might forget.
    edited March 2008
    Good, I was hoping you would chime in.
    That's it. 4 knuckleheads in one evening? I'm hittin' the date with the pillow early. Peace all.
  • Yashu
    Yashu Posts: 772
    edited March 2008
    Just more there to love, Treitz.
    edited March 2008
    venomclan wrote: »
    More like a Manley amp... too bad EveAnna's a woman...
  • janmike
    janmike Posts: 6,146
    edited March 2008
    With bluejean covered speakers you would have a match.
    Michael ;)
    NORTH of 60°
  • strider
    strider Posts: 2,568
    edited March 2008
    Here's your chance, guys. Just up on the 'gon.
    Remember, the ugly ones have to perform in order to justify their existence...
    Wristwatch--->Crisco
    VR3 Posts: 29,549
    edited March 2008
    That is one fugly amp.
    I dont care how it sounds.
  • sb_caribou
    sb_caribou Posts: 32
    edited March 2008
    even at 6.5, its gotta look better than that...
  • nadams
    nadams Posts: 5,877
    edited March 2008
    Zero wrote: »
    It looks like an AC unit.
    But I bet it functions quite the opposite. I would imagine it's quite the space heater!
    Ludicrous gibs!
  • TroyD
    TroyD Posts: 13,124
    edited March 2008
    I would rub my dingus on that.
    BDT
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2008
    I would rub your dingus on that.
  • TroyD
    TroyD Posts: 13,124
    edited March 2008
    stop being such a tease
  • mulveling
    mulveling Posts: 505
    edited March 2008
    I like the look, a lot. Bet it would look totally hot with tubes a'glowin.
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • shadowofnight
    shadowofnight Posts: 2,735
    edited March 2008
    I dont know, looking at that amp made me think of a little tune from AC/DC called " She's got balls " :D
    The first rule of Fight Club is you don't talk about Fight Club
  • John in MA
    John in MA Posts: 1,010
    edited March 2008
    I usually can tolerate fairly odd looking audio components, and still I think that's on the ugly side. Wouldn't kick it out of bed, though, as the saying goes. But it wouldn't win any beauty contests.
    My idea of a good looking power amp is a flat face, rack handles, and big meters. McInotsh MC500, for example.
    TroyD wrote: »
    BDT
    RuSsMaN wrote: »
    If either of you get near me, you're both going home sans-dingus.
