binding post polk R150
martin margolis
HI,does anyone know the diameter of the binding post on Polk speaker R150?
Post edited by martin margolis on
There are 2 diameters(and a possible third):
1) the hole diameter, or cutout
2) the outside edge of the terminal cup
3) the thickness of the metal post that you connect a single wire to
No matter what you'r asking, I don't have the answer. You should specify what you're looking for before getting random answers. -
SORRY! Forgive an old man who still plays vinyl from the 60's. I had to buy new speakers
because my vintage pioneer speakers bought 30 years ago or more were damaged.I bought heavy duty spade lugs from Cable pro.The lugs are supposed to fit a 5/16 diameter binding post. I bought them thinking they would fit my post,but they only go in so far. Customer service said that it will be fine. My next task is to find a crimping tool to crimp this heavy lug. End of my sad story. My wife is going to kill me.
A vinyl lover -
...wife is going to kill you cause your spade only goes in so far? Heard that story a million times. Can I have your audio gear?SAMSUNG HL-S42 DLP
harman/kardon AVR225
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000
