new comps for my civic
Kinetic
guys recently pioneer introduce the new 2008 line of speakers, so here in mexico the give the old ones a 40% discount and also good payment options.
well that was a really a good offer, and i could buy them from the oficial pioneer retailer from less than a used ones on "mercado-libre" (mexican ebay)
i put them on my civic my accord stays like that (all polk)
but the civic could improve from the OEM speakers to a set of REVS
here the pics of my custom install
i had to cut the bottom of the door to fit the woofers, and i cut the tweeter "holders" (i dont know a name for those) and try to fit them as the OEM ones.
what do you think?
here is the woofer without the cover
and here is the tweeter (i cut the "tweeter holder" to fit as OEM as possible)
here is the final pic without the cover
here is with the cover
and finally what do you think of the REVS?
i just buy them for the price and to match the sub...
my first impressions
the mid bass is horrible, but the highs are good, the sound is not to warm but works nice on pop, and techno music
what do you think?
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Polk Audio SR 6500
G35
Post edited by Kinetic on
install looks clean. as far as ur mids, does it make a diffrence with the window rolled up or down?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
^+1 on the nice install, sound deadening the doors may help with the midbassShoot the jumper.....................BALLIN.............!!!!!
its difficult to find good sound deadening and at a good price here, but i will try to buy some on amazon enough to deadening the accords trunk and the civic doors.
thanks a lot for the advise, im always learning here.Z
Polk Audio SR 6500
G35
