Emotiva XPA-2, What would be a good pre for it?
fatchowmein
I know, stupid question since the xpa-2 won't ship until early April. I'm just wondering what would be a good pre to hook it up to. I'm thinking about picking up a HK3480 or 3485 and the xpa-2 and hook up a pair of LSi9's but that might be overkill. Maybe a GFA-555 would suit me better.
Any thoughts?
The xpa-5 is now shipping.
Any thoughts?
Post edited by fatchowmein on
You should consider a higher quality pre to mate with the XPA-2. There are tons of options. I'm guessing this amp will be able to compete with amps three times its price or more, so if you get a marginal pre or use a receiver, I don't think you'll get the best out of the XPA-5. Of course, I'm partial to tube preamps, so that's what I'd recommend.
I plan to use my Emo LMC-1 initially, then move up a separate pre later when the funds are flowing better. BTW -- the LMC-1 for 2-channel playback is very, very good. I use the left & right fronts of 7.1 channel inputs (the ones used for SACD/DVD-A) because it's a true direct connect -- the volume control is the only thing in the signal path.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Nothing wrong with those HK's, they are very good as preamps. Much better than a lot of separates. Unfortunately I didn't have a chance to compare the Belles A21 that was here last weekend side by side, that might have been the first better preamp I have heard in my system. Might.
It all depends on the budget, like always.
Hmmm... I just may do that. Yeah, mating the XPA-2 with something cheap probably doesn't make any sense and I'm not sure if it makes sense to hook the Lsi9's to it but man do I want to hear what the 9's sound like with 500W.
I listened to Marvin's tube pre-amp a few weeks ago and I liked it. Pre-amp + SS amp may be in the future for me albeit far future due to budget constraints.
