wtb 1 piece of lsi7
SlowcarIX
SlowcarIX Posts: 887
edited March 2008 in Wanted (WTB) Classifieds
going to use it as center channel
any color is fine
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • fatchowmein
    fatchowmein Posts: 2,637
    edited March 2008
    SlowcarIX wrote: »
    any color is fine
    Thanks for driving all the way up from Austin to Sami. Good to meet you.
    I've tried using the Lsi9's for a center but I thought it projected too narrow of a field sitting on it's side so I imagine you may run into the same problem with the 7's. Currently, my 7's are on rear surround duties mounted up high so I don't want to take them down to test.
    If you look hard enough and with some luck, you may be able to find a Lsi-C, used or open box, for around $250-$299. I bought mine from OneCall as an open box for $250. Not a scratch on it.
    Good luck
  • SlowcarIX
    edited March 2008
    ditto
    how far are you away from the lsi center channel?
    my 7.(1x4) HT setup
    Buttkicker
