Pioneer speaker terminals
cambir
cambir Posts: 1,046
edited March 2008 in Wanted (WTB) Classifieds
I would like to find some speaker terminals/adapters for a Pioneer SX-727 receiver. Anybody have any laying around or have a non-working vintage Pioneer with some of the terminals in it? More than one pair would be great, but a pair would do for now.
Post edited by cambir on
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2008
    cambir wrote: »
    Do you mean terminal strip adapters? to use regular speaker wire?
    This is a trick offering from Prelude Audio.
    Cardas has barrier strip width spades for unterminated cables.
    You can also search for "forks" on eBay or McIntosh on Audiogon.
  • cambir
    cambir Posts: 1,046
    edited March 2008
    dorokusai wrote: »
    Yes? :confused: I don't know. Pics attached.
  • danger boy
    danger boy Posts: 15,722
    edited March 2008
    ugh I hate those things.. blech! they were used on the early model Pioneer gear.. i'm just glad they moved on from those eventually.
    sorry I can't help ya.. but check Epay for some.
    PolkFest 2012, who's going>?
  • cambir
    cambir Posts: 1,046
    edited March 2008
    I could use a new one of these too I suppose. :eek:
    What is it...do I need it?
  • dorokusai
    edited March 2008
    cambir wrote: »
    No, you need paddle spades but I'm not sure what size. You'll have to measure. You might get smaller spades to work but the paddles are stronger. Cardas makes them as well.
  • dorokusai
    edited March 2008
    cambir wrote: »
    It's an antenna for radio reception.It's very common in gear of that era....and older.
  • cambir
    cambir Posts: 1,046
    edited March 2008
    dorokusai wrote: »
    Just measure the length of the slits or distance between?
    dorokusai wrote: »
    That's what I thought. Why does it have this and screw terminals for antenna (AM, 300ohm balanced FM and 75ohm unbal FM)?
    Can I use the terminals instead or will it require the large antenna too?
  • dorokusai
    edited March 2008
    cambir wrote: »
    Yes, length. Either, it allows you to use an external antenna array.
  • cambir
    cambir Posts: 1,046
    edited March 2008
    dorokusai wrote: »
    Thanks Doro.
  • cambir
    cambir Posts: 1,046
    edited March 2008
    Measures the slits best I could, and here's what they appear to be:
    Horizontals 7/32"
    Verticals 5/16"
    Anybody have any they're willing to let go of?
