Broken amps! I want broken amps!
ben62670
Title says it. Looking for amps on the cheap to repair.
Thanks guys
Ben
Thanks guys
Ben
Ben
Ben
Post edited by ben62670 on
Ben I don't have a cheap amp for you.. but, how profecient are you in fixing a broken amp? right ch is out or more on a mid 80's Pioneer amp I have. I would like to get if fixed and put in back into service.
I don't of course have the schematics for it.. but I am looking for someone who know's their stuff and can investigate what the problem with the amp is. I suspect a leaking cap, one of the big caps appears to be leaking to me. but that's just eyeballing it. not really much of an educated guess.
lemme know your thoughts.
AlPolkFest 2012, who's going>?
Ben - I have an Outlaw M200 mono-block that the output keeps breaking up every once in a while. I am not sure if it's a bad RCA jack, or loose connection. It went back to Outlaw and they thought they had found a loose connection and fixed it, but then it started it again. It's not doing me any good setting in my closet, and I don't have use for a single M200, so let me know your thoughts.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I have a hafler amp that may need new caps.
Want to fix it for me? If so, Let me know how much you'll charge.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
OK guys. Just posting that I am researching all the amps posted. I am saving this thread, and will reply to your post. Thanks guys.
Ben -
I've got a Carver M200t that is stuck in protect mode....I have the service manual with the schematics in it, just lack the skill to play with it...I was thinking if I did get it repaired, I would like the spring clips replaced with a nice set of binding posts, and possibly a better set of RCA plugs on it.....
