Bi-amp center or mains?
iskandam
iskandam Posts: 704
edited March 2008 in Speakers
I've been looking for a multichannel amp for several months now and finally found a killer deal on a 7 x 200 wpc amp that's too good to pass up. I'm only running a 5.1 set up so I'm considering bi-amping either my center or the mains to use the extra channels.
I use my rig mostly for HT and I understand that 50%+ of all sound in HT come from the center channel. But when people talk about bi-amping they only do it for the mains. Is this something that would benefit music listening more than HT? Have people tried it both ways? If so, which speaker would benefit more from bi-amping in an HT environment?
Either option would require me to upgrade my cables since I'm currently running bi-wire Signal Ultras to the mains and a single Ultra to the center.
Post edited by iskandam on
    tonyb Posts: 33,068
    edited March 2008
    What speakers do you have and what is the other gear?
  • iskandam
    iskandam Posts: 704
    edited March 2008
    My mains are RTi8's, with CSi5 center, Emotiva MPS-1 7 x 200 wpc amp, Signal Ultra bi-wire cables for the 8's and regular single run Ultra for the CSi5. I'm using Harman Kardon AVR 247 as a pre-pro for now
    tonyb Posts: 33,068
    edited March 2008
    Tne amp is more than enough for your speakers,don't waste the time or coinage on bi-amping.Looks like you could benefit from a decent subwoofer though.
  • iskandam
    iskandam Posts: 704
    edited March 2008
    I'm using Velodyne CHT-12 right now, which is clearly the weak link in the system. I'm going to upgrade to an MFW-15 if I could get somebody to split the cost of dual MFW-15 in the LA area.
    The amp actually cost more than the speakers so I hate the thought of leaving the two additional channel of amplification unused after spending all that money on it
    tonyb Posts: 33,068
    edited March 2008
    Your not really "not" useing it.In a multi-channel amp,such as yours,you share the same power supply on all 7 channels.If 2 of the channels are not used,thats more reserve power on tap for the other 5 channels.You could always add some side speakers if you wanted to.
  • venomclan
    venomclan Posts: 2,467
    edited March 2008
    tonyb wrote: »
    Tony is most wise. I agree.
    Venom
  • Refefer
    Refefer Posts: 1,280
    edited March 2008
    Have extra channels is also nice in case you ever want to upgrade to the LSi series, or other power craving speakers. No one says you can't bi-amp in the future.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • Sami
    Sami Posts: 4,634
    edited March 2008
    iskandam wrote: »
    Others have already answered the main question, but I don't know why you would need to upgrade cables? If you're already biwired, just get a Y-splitter for the mains connection between the amp and preamp, and you are ready for bi-amping. Since you already have the cables (for mains), it doesn't hurt to bi-amp even if it isn't necessary.
    You don't mean to say you're considering bi-amping AND bi-wiring at the same time?
  • iskandam
    iskandam Posts: 704
    edited March 2008
    tonyb wrote: »
    The MPS-1 is a class H amp with an independent power supply for each channel. I wanted to add RTi4 or 6's for 7.1 but that simply isn't possible in my room layout
    Okay I never even thought about that. I still have a couple of Y-splitters from my dual sub days. Will put them to good use!
